Emotiva BasX MC1 (Pre + Pro) vs Denon 3700/4700
k_vijay12
Hyderabad
Folks, I was looking for a 9 channel AVR for last 6 months. The erratic price hike of Denon 3700/4700 kept me away from buying. Currently these are prices in range of 1.35-1.45L in India. Initial plan was to get this AvR and add LCR power amps later. if i am not happy with output.
My brother is coming from US in May ending. I m thinking if it is a good idea to get an Emotive BasX MC1 preprocessor from US. it is $1000. Translates to 75-77k post CC charges. But this would warrant power amps. I currently use an icepower based power amp in stereo, it costed some 23k odd to import. this delivers 68wpc in stereo mode at 8ohm / 220 wpc in mono mode at 8 ohm. Assuming i use monoblocks for LCR , and use stereo for rest , i would need 6 amps in total - 1.38L roughly. The sound quality is comparable to audiophile D class amps, but the down side of these D class amps is , they cannot be repaired in India if some issue happens. Thats the scary part. I wd have to change the whole module in amp.
If i go for new Emotiva BasX ...LCR 3 channel (140 wpc @ 8ohm) , rest 6 channel (80w @ 8 ohm) - this would cost 2L , Being AB class - i am assuming this is a reliable option from servicing stand point. But no idea of sound signature.
Last option is to look in used market. I did see ads of marantz 8077, 7 channel for 85k in the past, but finding such deals is not easy. even if i try used route - it would touch roughly 80-100k i guess for 9 channel power amps .
the pre pro option wd warrant speaker upgrades right away as well. People who got their Tonewinner AT300 - pls share your views. I am assuming both these r similar in architecture and hardware.
Lastly is Marantz 7706 pre is a better option? this costs about 1.3-1.4l i think. right away 60k more than this Emotiva MC1
Can some one play devil advocate and give me a differential analysis for this. Thanks in advance
Thats a great idea to go Pre Power combo. However, I would avoid Emotiva though. The forums have reported issues. On the other hand I would suggest a Denon, Marants, Yahama, etc receiver which XT32 room correction or equivalent along with full plethora of Pre outs. These receivers are tried and tested and you can be sure they will work and stay reliable. You can get power amps for the main channels. You can reach out to our DIY amp designers like @Aniket for his DD amp.
I use an Oppo 103D as a preamp with power amps and might go down the receiver as preamp router in future.
MaSh
MaSh
Does the Oppo come with any kind of Room EQ?
