Ethernet cable vs Wifi - what's better?
The last I checked, Moode didn't have integration with Tidal, Spotify and YouTube. That's a bummer.
I don't about YouTube, but Moode does have Spotify and Tidal integration. If you look at the Configuration-Audio page, you can enable the Spotify Renderer in Moode, enter your credentials and then stream from Spotify app as you do with any other device.
Tidal is a little roundabout. Unlike Volumio, there is no native interface for Tidal built into Moode but you can do it via UPnP. In the aforementioned audio configuration page in Moode, you can enter your Tidal credentials, go to a UPnP player app like Bubble UpnP or MConnect on your phone and select Moode as the UPnP renderer and play directly. Bubble has Tidal browsing built into it as well as Qobuz.
@rikhav As you rightly pointed out, the last Ethernet cable in the chain, the one going from the Google wifi node into the Allo transport, is the one that impacts the sound the most
