Fair price for Technics sl1210
Wharfedale EVO 4.1 4.2 Speakers
elt93
Goa, India
Hello.
I'm getting a technics sl1210 mk2 which is slightly cosmetically challenged but functionally good. What would be a good offer for it? It's coming without a cartridge.
anilva
Moderator
Hello.
Mint condition would be around 40-50K. You can scale down the price accordingly.
Cheers.
elt93
Goa, India
Thanks for the replies. Will be checking it out tomorrow. I'll inform as to how it goes..
elt93
Goa, India
So the seller has a pair and won't let go unless I take both of them. I'll be inspecting them tomorrow although I cannot afford both. If anybody else is interested in the second table pm me.
anilva
Moderator
That indicates that this pair is used for DJing and obviously not in good cosmetic shape. Might have taken a bit of beating.
elt93
Goa, India
That indicates that this pair is used for DJing and obviously not in good cosmetic shape. Make have taken a bit of beating.
That is true. But if everything is working fine there shouldn't be a problem right? Anything in particular that I should pay more attention to while checking the turntables? :rolleyes:
greenhorn
lots of vids on youtube on how to check an sl1200
usual issues are steady speed, sticking tonearms lights, functions etc
omishra
Pune
^^ Four feet,
Platter play no wobble and
tonearm not bent, no dent and no bearing play,
Arm Height adjustment works and list lock not broken n works,
que lever works - arm up and down
arm rest not broken
quad
Hyderabad
Make sure it holds the speed correctly, without any
fluctuations of the strobe markings on the platter.
If any fluctuations or runaway, the motor speed control ICs may be damaged,
and they are not easily available.
As Om mentioned, ensure platter bearing play/wobble and
no play in the tonearm bearings.
Check the pitch adjustment, if it is working properly.
Check if all LEDs and the Popup lights are functional.
Anyhow, if has been used for DJing, then you need to properly
service it.
Take pictures and post them here so more eyeballs can spot any issue.
elt93
Goa, India
So I checked them out. The tonearm assembly and everything seems fine on both. Had each table play a record for about 20 minutes. No fluctuations in speed. Pitch controls work on both. Here are the problems. One table's cue lever is missing. The on off knob over the main light is also missing on it. It's also missing 2 out of 4 feet. The other one is mostly fine. However both need a paint job. There are scratches and the paint is peeling off. But apparently the main things that is the motor speed and tonearm seem to be fine on both. Original asking price was 40k for the pair but they are obviously not worth it especially without cartridges. Should I pursue these? If yes then what should I offer?
I tried but I can't upload pictures here.
elt93
Goa, India
Will I get the required parts here in India? I'll offer 25k and see if the seller bites it. I was especially worried about the cue lever. Otherwise the other issues seem to be manageable.
anilva
Moderator
You will get all the spares on ebay.
Record Player
India, Bangalore
Every single spare is available for the 1200/1210 across various sites around the world. I've had good experiences with eBay, Amazon, technics1200s.com, kabusa.com to name a few.
madman29
KOLKATA
Paint job on any turntable is a tough job as you might not be able to keep the original markings and types intact. And the fact that they don't look OK might cause a lot of heartache letter on:)
elt93
Goa, India
I've repainted a dual 1216 before. My only paint job. It surprisingly came out very well. The only problem with this technics would be the lettering. I'd have to use stickers I guess.... Well I'm still waiting for the seller to drop the price. It's more of a project for me to pass my time... It'll also increase my limited knowledge with turntables... :D
