fake ebay spade connectors
krell
Usa
hi,
i purchased spade connectors from Ebay.
the description states it is gold coated and high quality.expecting cast brass/copper with gold coating.one corner the description states made in Germany.Got the parcel yesterday. opened and found the spades gap is little less to my speaker connectors. just try to little open. one was broken.
my surprise,it is made of plastic,covered with some shiny gold coating.
complete fake.
Pls make sure while purchasing something from Ebay.
Are you sure it is not metal? May be it is cast aluminum which has propensity to break the way it appears on the pic.
Even I don't think anyone will have audacity to fabricate a plastic spade connector. Did you check for its conductivity?
again..rather than buying cheap connectors you are better off with bare wire. connectors are where there is potential with higher degrade..you may lose the benefit of a good cable with a bad connector ;)
thanks for responding. i was completely disappointed while seeing that one. it is dull white finish. not checked the conductivity. let me check that one.
it is very light weight.not a proper spade.
Plastic? I'm shocked. I'm also rather amazed, because plastic would not be very cheap to manufacture. Maybe a cheap mould could be made for cast aluminium.
But I think it will work, because the metalic plating will conduct the current. Probably, though, not very well and not for long.
Go for bare wires. Unless the connectors are crimped by a high-pressure machine*, the contact strength in the connector screw, and it might just as well be at the speaker screw which reduces the number of unreliable metal/metal interfaces
*or ultrasonic welded :D
thanks for every ones response.
yes, i shown this to my friend and he confirmed me it is cast aluminium but of very cheap quality.finally i dropped the proposal and using the bare wire.
thanks all for your support and response.
regards
