Floor standers for Audiolab 8000A
visquare
New Delhi
Hello,
I need advise on buying Floor standing speakers in Delhi. I have Audiolab 8000A amplifier and Cambridge Audio 640 CD player. My budget is around 40,000 and I listen to Western, Indian classical and Jazz.
Vikram
Hi:
I'd look at warm-sounding speakers that's within your budget for your 8000A, and some options are:
Diamond 10.5
KEF iQ50
Quad 22L2 [s/h]
* Quad 22L or 22L2
* Wharfedale Diamond 9.5 or 9.6 or the newer models (10 series)
* Tannoy Custom F4
Ramesh @ Bangalore
Try the Dynaudio Audience 52 or 62. Some one in the Forum was selling his Audience 52 for a attractive price. check it out. Audiolab with Dynaudio will a better bet then the other combinations mentioned. just my opinion.
edit: Just read that you are looking for a FS. then try the Audience 62.
* Quad 22L or 22L2
* Tannoy Custom F4
Ramesh @ Bangalore
Ramesh how would it sound with my Vintage Speakers? Plz advice..
helium
SB Classic -> Lyrita DIY DAC Philips TDA1543 -> Vintage Akai Speaker SW175 / Highly modified B&W DM4 -> Lyrita IC + Cables => MUSIC
Do u have the room for floorstanders ..if your room is let say less than 180 sq feet. Bookshelves make more sense .
A pair of bookshelves in the same price range vs a budget floorstander ... the Bookshelf would be way better.
But if floorstanders if what you are looking for
Wharfy 9 series (9.5, 9.6), IMO is def better than the 10 series. However they do need sonsiderable amount of power to make them sung .. with lower rated amps. you will miss out on detailing at lower volumes. Unless u generally listen to your music loud.
Take a look at Paradigm Monitor 7 /9 . it falls in your budget .. with a highish sensitivity. your amp should be able to drive it pretty easily .
I had the PMC bookshelves but wanted a room filling experience with a huge sound stage and super tight bass.
