Today got my DAC 24Bit/96kHz (AUDIOTRAK PRODIGY CUBE -Wolfson 8776). It's a basic DAC but the reviews were good so thought to give it a try. I was already using Foobar2000 with Wasapi but now I want to make things more organized.
I have huge collection of uncompressed music (.wav 16Bit/44.1kHz) copied from my ACDs (around 600) to easy access.
So I have couple of questions, I hope I will get some help from FMs.
1. As the DAC supports 24Bit/96kHz, should I change the settings in windows?
Control Panel > Hardware and Sound > Manage Audio Devices > Advanced (16Bit to 24Bit)?
2. What Wasapi setting I should use? Event or Push?
I need accuracy. However I have used both and found Push sounds flat and neutral but Event sounds a bit colored and felt very slight delay (not sure if it is because of Buffer Length)
3. What is the best Buffer Length? Tried few (say 50-1000ms) but could decide what should I keep.
4. If I use Wasapi Event, the visualization spectrum frame rate becomes slow but it works fine in Push mode. (It was working fine but I guess I did something wrong
5. Components > Advanced > Playback > Wasapi
By Default Hardware Buffer MS for Push is 200 and for Event it is 25, I have tried it 200-250 for Event.
6. As my whole collection is 16Bit/44.1kHz, I am not sure I should change the output format to 24 Bit [Dither Unchecked] or keep it default 16Bit.
(Components > Output)
If anybody already did some R&Ds on it and share his experience, would be great help.
