Frugel Horns with Alpair 7.3 Drivers
captrajesh
Moderator
Staff member
Mumbai/ Hyderabad
It is the same carpenter who is making my speakers who is making these too. The cuts etc. are fairly easy except for the joint between back and the middle panels.They are almost done.
.It should be 70 mm from top to centre of the Driver + 18 mm of the top piece. See this pic from plan...
there seems to be a size difference of 11 mm in overall dia between Alpair 7.3 Gold and MA CHR 70.
That's precisely why the confusion as to how the drivers should be spaced.
Re: Yet Another Frugal Horn
The cuts are almost done.
Wonder why sathiamoorthy is not posting any pics yet... :sad:
Capt, if you go by the same 70 mm CL you will be left with just about 20.5 mm from top of the cab to the rim of the driver... which is barely enough for a grille, if you are planning one...
However it will be interesting to see, how you are going to locate the CL on the sloped baffle, which is a different plane/projection as per the drawing... ;)
May be you need to do some compensation... by adding 1 mm to 1.5 mm... :D
All the best to sathiamoorthy's quest... :)
