Hathway STB to BPL KTR TV audio issues
mithunp
Hello,
I have a Hathway STB (non HD box) which is active and been used for many years. I have a second TV (BPL KTR 14 inch 2001 model). Today I connected the working STB to this TV, and interestingly all that I see is only Video and absolute no "Audio" in TV for all channels.
I did connect the Hathway STB IN with Cable TV connection that comes from the internal wiring of apartment and OUT with a cable that connects to TV.
Apart from this the cable that has Yellow, Red and White, I did connect to Video IN and Audio IN of TV. Interestingly the BPL TV being old model has only one Video IN and Audio IN Vs todays LCD/LED which had 3 input pins or more.
I also changed this cable with another working one, but Audio is Zero.
I also connected another AV player to TV, all good. So TV and cable but not a issue.
I also then took the STB back to the LED TV where it was earlier connected and all again good with perfect Audio and Video.
So not sure if there is any compatibility issue between TV and STB or what?
Can any one help here....
Mithun
