HD900B: unable to setup DTS-HD and TrueHD
shobhitk
India
[Solved]HD900B: unable to setup DTS-HD and TrueHD
Hi everyone,
today i received my HD900B! great player...plays everything flawlessly.....
i have one query though. i may be doing something wrong but i played 2 test files, one with DTS-HD MA and the other with Dolby TrueHD but the correct light in my AVR did not light up, instead the AVR showed ONLY DTS and Dolby respectively.
please someone guide me so that i can get it going correctly.
i have already set all my audio options to output as RAW.
*my AVR supports both DTS-HD MA and Dolby TrueHD
*the files being played are taken from High Definition Trailers (HD) - Demo World and are in m2ts containers
Set the speaker output to 7.1 in your player and set DTS HDMA and Dolby TruHD to raw. IIRC, there is an option where you can specify whether to use 7.1 or core only.
i will definitely try setting it to 7.1. i had currently set it to 5.1 because my receiver only supports 5.1. will 7.1 create any issue?
This won't cause any issues. Only when you set the output as 7.1, you will see options for hd audio settings.
thanks baiju! after switching over to 7.1 HD Audio both the DTS HD MA and the Dolby TrueHD lamps are lighting up nice and bright! :)
