I have jamo s606 with yamaha rx-v 673 and its just perfect match according to me and for sub go with klipsch or velodyne
Hello Amarendra
I am using Denon AVR-3313
This is good Reciever and one thing from my side. Denon And Marantz are from D&M Group.
Marantz uses good components than Denon.
This is the general fifference.
Thanks for your suggestion, any specific store you have in your mind for velodyne sub in Delhi region.
AUDIO wise Audition is the best way to compare taste differs person to person.Please suggest between marantz 5012 vs denon x3400h.
I would prefer Denon over these two for Front display.But if you compare it side by side Denon has 3 hdmi output but Marantz has 2 hdmi out with traditional 7.1 channel input.
Both has 7.2 pre out which is great addition in this step.
Finally its your call and your Ear has to justify them.
All the best
[emoji41]
Try Profx .its being latest model its doubtful whether it is available for demo.Thanks, i believe marantz can be auditioned at mz audio. Where can i listen to denon x3400h?
Where are you located?Thanks, i believe marantz can be auditioned at mz audio. Where can i listen to denon x3400h?
Between the two, it should be Denon x 3400 for its Audyssey XT32 than the Marantz 5012 with Audyssey EQ XT ..
Mumbai there is a Profx outlet.I am from Indore, most likely will be coming mumbai nov 2nd weekend.
Does xt32 make big difference?
