Help on removing the some rubbing noise from voice coil of a speaker
  • Thread starter Thread starter Deleted member 45006
  • Start date Start date
D
Guest
My infinity reference 30i woofers makes some strange voice coil rub noise when it plays some sounds particularly something similar to a piano ..and light vocals , this is not there when the cvolume is turned up, my amp is okay, as I m getting the same problem with two amps I m having
