Help with Manual EQ - Onkyo TX 608
sl4y3r
Hi All,
I have a strange issue. When i run Aydussey on Onkyo 608, It sets up my fronts (L and R) perfectly. They sound superb. But my surrounds tend to sound less crisp. My L & R sound extremely dull with the Audyessy turned off.
I need help on the best way to tune my fronts to get the sound that Audyessy tunes it to get.
I have tried all settings in the manual EQ. Below are the settings i have access to.
(Gear in Signature)
Thanks,
Lee
I use a Marantz and ran audyssey a couple of times....once settings were done, I adjusted manually each speaker so that I get the best EQ output....so far loving it....works like a charm....I am sure there would be some step you are missing out on...check again,,,, all the best
@spirovious-Hmm.. Probably i will re-run it and see. Thanks.
@efernand - I cannot manually tweak the settings if i use Audyssey. Thanks anyway.
