Home Theatre combo Question
knd
Hello Friends,
This is my first post on this site, but I have been reading through the community for a quite some time.. Great place..I have recently finalized by HT components and have placed the order for the below after a reasonable amount of research. Just needed some advice on whether this makes sense
Projector - BenQ W1070
Speakers - KRK Rokit 5 + Rokit 10 Sub
Pre amp - Marantz 7701
Screen - 7 ft wide
room size (LXBXH) - 12X10X8 feet (not very big, hence Rokit, even though they are near field studio)
Completely closed room with no ambient light
Thank you in advance for all your comments and be gentle :)
PS: The choices had do a lot with budget available
Power amps are not required since the rokit 5 is an active speaker with built in amp. Am I wrong? BTW, I am using 5 Rokit 5 along with the rokit 10 for 5.1 surround. Thx
Hello Friends,
Screen - 7 ft wide
Chief can u pl share the pricing and have u installed .It will be helpful as i am also in a process of setting up HT.
Hi Poppy,
The Rokits are about 1.1 L
The Benq + 3 glasses are about 1.13 L
The Marantz is about 1.23 L
Hope this helps. But there are others posts that refer to cheaper prices by online purchase, but I am more of a touch feely chap :licklips:
