Home theatre for bedroom
joshiks7
solapur
hi,
My bedroom is 200 sq feet in "L" shape. My TV is in middle of one arm of "L".
Viewing distance is 10feet. Sound of Sony 32Cx420 is going to leak at back of bedroom too.
Whats best system for this---
Sound bar?
3.1 OR
5.1
OR
Experts feel ki only LCD speakers would be enough.
Since its bedroom, budget is bit tight-approx. Rs 30k.
Kindly help.
HI friends,
any views?
OR
I have little space constraints in bed room. I am little skeptical about AVR space in bedroom.
Kindly suggest me how is the SOny or Philips 5.1 system with DVD player with in built amplifier which is space saver?
hi,
Sound bar?
3.1 OR
5.1
OR
Kindly help.
A Good Sub-Sat combination could be an ideal consideration....It will not produce the soundstage of BS which i hope you wouldn't need in bedroom...
If you treat your bedroom like a bedroom get a soundbar. They won't give you the loudness but keep your bedroom clutter free.
in my opiniioon at 30k...just get a onkyo 3400 or yamaha 296 htib set up..best.
get a mistry and make the speakers wall mount,you are clutter free.and you can keep the raer speakers not connected...just a 3.1 set up.
or can go for a stereo option.
it would be nice if you share what will you hear..is it mainly stb sound,if yes can go for a nice stereo set up from stb RCA source.although take in mind the stb RCA source is not good sound....
a sonodyne integrated amp and a pair of sonodyne sunus or wharfedale 9 sereis bookshelves.....well within 30k............
stereo is good for future...the int amp and speakers can be used in other purpose also....
Its really difficult to place 5.1 in my bedroom due to space at TV unit is small.
Planning for sound bar. I have come across Boston acoustics TVee Model 30 and TVee model 25. Hows this? Which is among two and whats approx. cost?
Since it has wireless woofer, does it interfere with WiFi signals on single band router(This has been reported with POLK soundbar).
OR any other good bar around Rs 25k?
Kindly help.
Kindly help.
Check out the Sonodyne Ex sound bar......Soundbar for 25K......
(or) You can look at Wharfedale LCR
Wharfedale DIAMOND 10.LCR
BA soundbar comes with separate woofer while wharfedale not, any practical significance?
BA Soundbar will give you a Virtual surround effect 5.1 while wharfedale Diamond LCR will actual 5.1 Sound if you add surrounds & Subwoofer .....
If you exclude surrounds, you will get 3.1 sound..
