How to Bypass audio from blu ray to AV receiver to decode it.
jayvnandu
mumbai
Hello friends,
i recently bought an orei BDP-M2 region free blu ray player. i connected it to my Marantz sr5007 receiver via HDMI. Now the problem is i want the receiver to decode the sound and not the player. I checked the seeting of the Blu ray and nowhere could find the audio setting. so My question is.
1) how do i by pass the sound from the blu ray to the reciever for it to decode.
2) the sound does not say dolby digital or DTS - MA. it shows multi channel stereo IN or Multi channel stereo whenever i play a blu ray.
Help?
The setting for bitstreaming is usually under the audio settings of the bdp. You may have to set it to bitstream or RAW. Isn't there a manual for your bdp?
Kindly list all available options you see under Audio setting for you BDP. The official product page doesn't even have a User manual on it so its hard to guide you.
i think so, it would be of no use if i cant bypass the audio from the bdp to the reciever for it to decode.
