how to connect sub woofer to Lenovo PC
Marinerme
I just purchased new All in One PC Lenovo C 340.This one is bulletin Dolby Advanced Audio. but lack the Bass. i want to connect powered sub woofer.The Monitor is with HDMI,USB ports.how can i connect the Sub.I dont want to use head phone out that way monitor speakers will be Mute. ???
Thanks for reply. can you explain 3.5mm splitter in details, and where to get it. If I connect sub woofer with HDMI with 3pin RCA or USB with 3pin RCA ???.Will it work welcome your suggestion.
regards
Marinerme
HDMI to Composite (3 pin RCA) sounds good. I wonder if it will work unless the Video jack is plugged in to something. Also, will the sound travel through both HDMI and line out (headphone out) at the same time?
A 3.5mm splitter has a stereo (3.5mm) male jack on one end and two 3.5mm sockets (or 3.5mm female jacks) on the other end. Connect the male jack to your computer line/hp out and use the two female jacks to connect to your monitor speakers and sub woofer.
You can also use this splitter to connect two headphones at a time. Below are the other type of 3.5mm splitters
http://img.alibaba.com/wsphoto/v0/400259619/3-5mm-Audio-Splitter-for-iphone-ipod.jpg
http://img.dxcdn.com/productimages/sku_2716_3.jpg (I have this one, better looking mfg by MX)
