I'm a bit worried about the idea.
Even a modest turntable must rotate at correct and consistent speed. How much of this achieved by inertia of a heavyweight platter, and how much by other means of control is in the hands of the designer. If he fails, his turntable is not worth buying, let alone modifying.
Correct speed ? Yes. And most do, but that is at the macro level, at the level where it is measurable through a stroboscope. But at microscopic levels there are fluctuations and these are easily caught by the cartridge.
Macro, mini or micro --- I'm sure you'd agree that correct speed is so absolutely fundamental to a turntable that it should just be ...right!
But yes, nothing is perfect, there are tolerances, and I suppose tweaking is to do with reducing those tolerances.
Hence (I imagine) the 401 and other great idlers had correctly a less powerful motor, but the 301's heavier motor lends it the greater mystique.
