Have been connecting Pixel via bluetooth and playing on Spotify :-/Subscribed!
@ankitbhargava if I may ask few questions, how are you listening to audio in the current set up?
Is it an Android Auto/Car Play unit? If yes, are you using your Pixel connected with USB cable? Finally what music player are you using on your phone?
And for me, the only time I get to listen to music is in Car :-D .. amazing audio make car amazingyou'd perhaps be surprised at how little many of us know about car audio and how badly its setup in most cars![]()
Do you have USB connection option? If yes, try that next.Connected spare iPad using Aux
I do have "iPod" port, shall try that too.Do you have USB connection option? If yes, try that next.
If Aux is the only option then iPad HO is not that great. A good quality DAP or a Portable DAC or even a LG Quad DAC phone would be so much better!
Considering you listen to music mostly in car, you definitely need an 'upgrade'.![]()
search for Gunbir on this forum he is the best guy for top spec cars . they have alot of options to take stock audio to next level without damaging stock cabling.
you are welcome brother !I do have "iPod" port, shall try that too.
Took a lead now and ordered a Dragonfly RedI do remember seeing some FiiOs in the sale section here. They could be worth checking out.
I can also suggest checking out Shanling Q1 and Activo CT-10. Both available locally, priced well and good sounding.
and its DC 5v ... right?Not sure if this thread is still active.. However recently got hold of xDuoo XQ-50 Pro - You can source from Bangood or HIFiGO, with duty will come less than 7 K. It takes USB C power and out digital OR L/R analog out. Can take LDAC and AAC should suffice for Good wireless.
If planning for complete rewamp checkout products from AudioControl, they haves specific options for upgrading Factory settings.
Most Factory settings will kill bass to avoid the issue with their weak speakers. Try SOund deadening from Naico -> Speaker Upgrade -> AMP upgrade
cheers,
kannan
Got 96Khz working using DragonFly Red(that Magenta LED indicator brought a big smile on face)
Apple Lossless sounds incredible in Car, just incredible.
Clarity, tight bass, separation, crispiness ... everything has improved.
I had to use MacBook since I had issues with using my Pixel4 Phone to stream lossless on Apple Music App.
Somehow the output was really really low. Had to turn up Car Audio volume to 100%. I will sort that later.
Bose uses the same method in their home theater and portable products. The idea is to reduce distortion at higher levels that is associated with smaller drivers like the ones bose typically uses.I saw a video on YouTube where the installer mentioned that the meridians system reduces bass as we turn up the volume which makes it hard to use the headunit with a dsp. Not sure if he said that just to highlight his build or not.
