j river media jukebox question
nandac
on jrmj i am not able to get the view like itunes - where i can see all the songs. instead i am only able to get a windows explorer kind of view - directory -> subdirectory -> songs.
i like to play the shuffle option on my entire collection, which i am not able to do with the above.
any idea how i can get the itunes like view on jrmj?
btw i find significant difference in sound between 256 kbps mp3 and uncompressed lossless (using dbpoweramp - thanks mazhar!!!). latter is more substantial, fuller and detailed.
Great;
Yes, Wave & Flac are the way to go.
If you are to use Flac - unsure that it is @ 0 % Compression. This is very very important.
Do not play any music on any compressed format;
Enjoy your music. !
:ohyeah:
