Length for Usb Cable from pc to dac ??
SBalaji
Bengaluru
hai friends i am using an audio gd fun dac and i would like to extended the length from 1 m to more. So whats the maximum length possible considering a budget of 2-3k max ?
..using an audio gd fun dac and i would like to extended the length from 1 m to more. So whats the maximum length possible...
While shorter the better, technically, you should be fine up to 5m without any perceivable/audible loss in quality.
I have used upto 4 meters between PC and DAC without drop outs.
I still have that cable. It is a green colour Forest cable from Audioquest.
Shorter is though advisable unless you are constrained to go with longer cables.
What are you using currently?
I am now 95% on digione signature, so use digital coaxial cable and not USB.
But occasionally I do use my laptop with the 4-meter Audioquest USB cable so that I can operate it from my listening position and simultaneously use it for my office work also.
Other than that, I have a cable that came with the DAC which is around a meter and another very short 20 inch cable which I was using with USBridge and USBridge Signature
Any particular reason shorter cable is advisable , since you have both the cables did you notice any difference whilst using both ?
Have used the longer one with laptop n the shorter with the USBridge. Never compared simultaneously. Will do sometime next week and update.
I am using a 4m audio quest cable from my dac to amp. The amps inbuild wifi receiver sounds better. Not sure if it is coz of length.
