LG 50PB6600: How to play images in a loop?
Audiolab 6000A Amplifier
anga
Hi:
Just got a new TV: LG's 50PB6600.
To guard against burn-in
Downloaded 20 images (jpeg) from the link inPlasma Break-in: How To Properly Break-in Your New Plasma Display - Home Theater Forum and Systems - HomeTheaterShack.com
and copied to pen drive.
1. Changed input to USB
2. Pressed green buttom with .. on it to change to select mode
3. Selected all 20 images
4. Pressed red button with . in it.
5. TV displays first image and stops.
How do I get the TV to loop through the impages continuously?
manniraj
Hi:
Try the slideshow option and then if possible use the "Repeat" option on the slideshow. If not possible I think you need to check on the net how to make a movie out of these images and then to repeat it in a continuous loop.
anga
Thanks you.
I am still new to this and the user guide is of no help.
Please provide details.
anga
While I am comfortable with computers and programming, new to video field--so details will help.
1. Ideal would be to run the slides in a continuous unending loop. If you own a LG 50PB6600 or know how to do this, please post steps.
2. What software (free) can I use to convert the slides into a movie? How many slides per second or minute?
3. How do I play this movie in a loop?
Thanks again
anga
Update:
1. SOLVED
2 and 3: open
In case someone needs this info:
Go into the folder containing images.
Press the green button with .. on it.
Move to each image and select by pressing the OK button.
Select all images.
Press the red button with . on it to start playing.
It will display the first image and stop.
Press "settings" and choose fast play and your choice of transition between slides.
Close this window.
Press Info.
Press down button and select Play (>).
Done.
