Looking to upgrade soundcard from Audigy2 ZX Pro
EtrnLwanderer
India
I have been using a Creative Audigy 2 ZX Pro paired with Gigaworks S750 7.1 speakers for my computer. I am planning to upgrade to a sound card that supports Win8 as my old sound card does not have support for it any more. The speakers work flawlessly so I dont intend changing those and additionally they are routed through the Creative DDTS-100 which enables me to run my PS3 also on the same 7.1 speaker config.
Price is not a criteria but I would like a recommendation as to which sound card would go best with my 7.1 THX certified Creative S750 speakers.
All pointers would be highly appreciated. Thanks :)
The D2X is a sound card released in 2008. Not sure if it has driver support for Win8. In fact it isnt even listed on the Asus website for India any more.
@EtrnLwandere: You can look for the Asus Xonar or Essence series sound cards. And if you want better than Asus, then look for ESI Juli@ or RME cards. They are very expensive.
And if you are using Creative DDTS-100 then try to route your sound card output through optical/coaxial.
ESI Juli@ is not very expensive, and is the darling of many music lovers. It might be the best value for money, and it's audio quality might be hard to beat without spending a lot more. Problem: Isn't it only 2-chanel stereo, whereas EtrnLwanderer needs 7.1?
RME is moving into semi-pro/pro interface land, and getting very much more expensive. They also cater for studio protocols, rather than domestic analogue out. I was very much in love with my RMI card: it gave me one of my hifi-Wow moments... It was simply 2-channel i/o, analogue/digital, and I don't think they even make an equivalent now.
It's interesting to see audio-myth-buster Ethan Winer on just how much difference there is between an "ordinary" sound card and expensive, high-end studio equipment. It is not as much as we might think or hope!
In my early sound-card experiment days, a Sound Blaster was correctly named. Now, even mother-board builtins are at least half-decent.
@snkadh: Thanks I'll look up the Asus series as I'd rather not sacrifice the 7.1 speaker system by tying it to a 2 channel sound card.
@greehorn: I did try the daniel K support card on Win7 and wasnt too pleased with the output nor interface. Hence the reason I'd rather go with company driver and software support rather than 3rd party ones
@Thad E Ginathom : Thank you. I will keep the ESI card suggestion filed away for when I want to hook up a dedicated 2 speaker audiophile oriented rig, but for now I have to compromise the system for both music, movies and PS3 games :)
Don't use the stock driver what comes with D2X because it has some installation issue with win7 (64) & win8. You must use "Asus Unixonar Driver" for D2X. It is more stable and give U a problem free installation. I personally doing that way for my D2X with zero problem.
This is madness!
w24mVL
