Max length for Stereo cables
jbgude
Edge of reality
Folks
What would be the max length that I can use to connect up a pair of Wharfedale 9.6 speakers ?
(Incidently, I heard and checked out the 9.5 simultaenously and found the Bass response far superior with the 9.5's !- however the mids and highs were clearly inferior, and I finally chose the 9.6)
I would like to run a cable over a door frame ( 8' x 7') plus some extra to hook up to the amp and speaker - I would estimate that I require around 11 meters length : would this result in a serious loss of performance ?
I have at least three amps that could be used.
Denon PMA 500 / Cosmic CO 100 / Sony AVR ( quite high powered )
Would also appreciate advice on the better / mid price range cables available in Pune / Mumbai with an indicative price.
Thank you.
Folks
Thank you.
Check details-
Speaker Wire: Choosing and Installing
Speaker Wire
very useful for me.
I assume you are referring to speaker cable rather than stereo cable (analog RCA). These serve entirely different purposes.
If you are planning that long a run speaker cables then you can go for 14 or 12 AWG.
amazon.com has cheap cable if you do a search even with tax and customs
Thank you both, I appreciate that. Did not realise that people have requirements for far longer cables :o:
I shall have a look at the wires available locally, as I have problems with ordering via the net and especially doubts on receiving them safely by post.
