Modular Subwoofer Amplifier build
Thanks for the links. I am thinking of a DIY from scratch. As the chips are relatively inexpensive(Rs.75), it doesn't hurt much to smoke a few in the process :)
Where did you find them at Rs. 75? I am also looking for buying 2 for my stereo amplifier, although I stay at Hyderabad.
Update...
Removed one slave from the circuit. This is done after reading that for simple parallel application, recommended maximum is 3. I will first try with a single PCB with 3 ics in parallel and if I need more power, two similar boards can be connected to work in bridged parallel mode.
Another small change brought in is to increase the bootstrap cap to a higher value to aid better low frequency operation.
Here is the updated schematic.
Reviving this project.
Made PCB layout today, here is the first version.
edit: There was an error in the PCB layout, corrected image is attached.
I missed this thread when it was originally posted (2011), just saw it now. For higher-power applications of the TDA729x, the parallel schematic shown seems to be more robust than the Class-G schematic shown on the ST datasheet/appnote. Apparently, the Class-G schematic requires very precise rail sequencing, which is generally only possible by exactly following the ST schematic. Many people who tried to modify/improve that circuit ended up with smoke.
Also wondering if a parallel or bridged TDA2050 circuit is feasible - there's presently a closeout sale on the TDA2050 (which ST has stopped manufacturing), and prices will be very reasonable as long as stocks last.
On a related note, I'm revisiting the parallel MyRef-X2 variant with 2x LM3886 per monoblock which I prototyped a couple of years ago - the immediate motivation is that I tried a variant of one of the alternate Rev C compensations today, with some upgrades to various passives, on one of my earliest Rev C builds, and the audible sonics turned out to be very well-balanced. That leads me to believe that this will work well with similar improvements to the MyRef-X2 as well.
I can share the PCB source files if you need them.
On a related note, I'm revisiting the parallel MyRef-X2 variant with 2x LM3886 per monoblock .
Linux, if you ever do make one of these, let me know, If we can fit the whole thing on a heatsink (aka plate amp) I would be in the market for one.
