keith_correa
Newer thought it would sound so good!
So, apart from "sound so good" how does it sound? C'mon man, please use some audiophool/oddiophile terminology. Here's help. :lol:
Just purchased the linuxguru version of the Rev C will update you about the built as soon as I get the kits.
Anyone here planning for a more advanced amplifier comparable to 40K-50K commercial amps?
I have about 10 different projects to complete and a lot of components that I wanna to use. most of the boards are ready. I am only searching for good enclosures which are difficult to find in India and costly to import. I am enumerating the projects that are ready to be boxed.
1. DIY Etched Power supply board having 40000 MFD 100VA ALCON capacitors 30-0-30 with dual regulated 0-12 volt supplies.
2. Elektor Parametric equalizer.
3. Elektor Linkwitz correction network for subwoofer.
4. Elector Electornado mono 100W RMS subwoofer amp.
5. STK 4141 Populated Amp Board from 1997.
7. Dolby Surround Sound Processor Kit
8. Tube Preamplifier
9. OPA627 based preamplifier
10. Elektor Discrete preamplifier
11. 3 Way active crossover network.
Most of these were made 10 years back. Want to convert these into some meaningful things that I can use. Will post the pics If you are interested.
At the same time I am planning for some advanced builds that's why need advanced designs preferably kits as sourcing components is a spoiler. No problem with soldering. Started soldering from class 10th (15 years back).
Please give us more details of the floor standers, to be able to give any meaningful advice. Size, type of enclosure, what are the other drivers in the system etc. I see an automobile driver being used a midrange and a HF driver.
Cheers.
Nice build. You have to tell us some of your secrets. I've built some GC's - 3875, 3886 & parallel 4780. Great sound within their limits.
Sunil
