- Joined
- Mar 11, 2010
- Messages
- 3,129
- Points
- 0
Hello TT Guru's (You all know who you are )
Need your advise on the foll TT
NAD C555i. Hows it???
What would be a good cart to go with it??? LP's played will be mostly of Rock & Metal Genre's, hence suggest a good cart for the same.
PS: TT already bought by a friend of mine residing in the Gulf, so really need quick pointer on the Cart - Thanks!
