I got my hands on a 10yr old Nakamichi AV10 without the manual but managed to figure out most things with the exception of the Speaker Calibration.
I have set speaker modes (small , large etc) but usually in most amps you can set speaker distances and the amp works out delays etc - later ones have built in calibration software.
Does anyone know what the numbers that appear in the Nakamichi speaker channels relate to. Is that feet distance or metres or a sound level. Also would you be able to use the test tone with a SPL meter to output a steady 75db signal and calibrate.
Question is how.
BR
Question is how.
BR
