need help buying simple 2.1 speakers or soundbar with woofers under 12k
rahin88
Hello guys,
I was looking for a simple soundbar/ 2.1 speakers for my 40 inch TV in budget. I was searching for something less than 12-15k not more than that.
I found this Samsung HW-F350 soundbar for 10k worth it ?
Aditya
As mentioned by FM's above you may also want to try on JBL SB-100/SB-200 if you are looking for sound bar with +/- 2000Rs.
for TV purpose...
get a simple local amp--2k/astonia--6k amp..a pair of bs with rest of money..(try used)..
this will be best possible combo
they are solid..unlike the tiny soundbars or 2.1 pc speakers
for TV purpose...
Any idea where in Delhi I can find local amps? Or any available online?
try the corsair gaming audio Series SP2500 2.1 PC Speaker System
you stay in delhi...good...i think local amps is cheapest in india in delhi..
check delhi 6,any wholesale electronic market
for online astonia chek e bay india,or direct mail into astonia audio
norge is also a very good mumbai based budget brand..but it will be around 8k for the amp i think
also check fourm's sale section,you may get a good deal in used bookshelf speaker
