gudu
Need info regarding entry level CD player:
Thanks for giving suggestions regarding AMP and Speakers. Both are on the way. Will be getting it shortly.
Now comes which CD player to buy.
My friend suggest, dont go for DVD player. It got 5.1 sound. As I brought speaker and amp only to listen to music, only CD player is enough, which can play normal audio CD and MP3 CD's, which has got USB option.
Can someone suggest a CD Player which has the following:
1. Can play audio CDs.
2. Can play MP3 CDs/
3. Should have USB option.
4. Should be able to connect to graphic equalizer and/or amplifier.
Budget less than 10K.
Any brand would do.
Thanks in advance. Waiting for suggestions.
Any brand would do.
