Need information on Samsung LA46B650T1R - Series 6 46 inch LCD
Miany
Kerala
The spec says 100Hz motion flow. so is the Refersh Rate of the TV 100Hz?? Sony explicitly says 100Hz for PAL and 120Hz for NTSC.
I was wondering if the TV can do 24Fps without any pull down if it is 100Hz. Does samsung support 24Fps without any pull down? Also what if i give an input video of 60Hz. what will the TV do in that case??
