Need new headphones/iems for under 1.2-1.3k
shivakanth.sujit
Hey all!!
My first post here so pardon my inexperience :)
As the title suggests , I need a new set of headphones or iems for under 1.2k
Uses : Gaming, movies.
Also for gaming, which would be better, iems or headphones?
Thanks in Advance
Shiva
No headphone under 1.2K is good for gaming. If you can consider IEMs, then there are a few. What you need is a headphone with good soundstage for pinpointing directions like enemy footsteps & good bass for effects during explosions. Mike can be attached separately. The cheaper ones seldom fulfill these 2 main criterias. So I'll suggest you increase your budget a bit & look for a second hand headphone or pull the trigger on a Soundmagic PL30. I've used PL30 with a Zalman mic during CS Lan gaming & was very satisfied.
