Need some quick help..
Easylistening
Hi, I have a couple of urgent q's that I hope to get your expert advice on:
1. Can you suggest names of companies that make good compact audio systems that are available in the US. The only condition is that the entire equipment should come as 1 box and hence will count as 1 piece of checked-in luggage. Someone suggested Harmon's MAS 102. Any others?
2. My HOnda City Gxi CVT came with a factory-fitted Alpine HU with a tape deck. Is it possible to connect my ipod to this as there's no AUX-in thats visible to me. If not, can you please suggest names of not too expensive HU's and dealers in Mumbai (Andheri East or Powai area) that these HU's are available.
Hi - I have see those cassette adapters that allow you to connect a portable audio device via 3.5mm headphone socket. Not sure about the AQ of these devices. You may want to check those out. I think they are not too expensive.
chk this link cassette adapter | eBay
Thx,
~s~
