Nelson Pass F5 Clone Kit
suds
Bangalore, India
F5 Complete Kit with Components.. (Only within India)
Kit includes only Electronic components,
PCB Spec: Double Side, 2.4mm PTH (Plated Through Hole), HAL, PCB with Solder Mask, Legend.
Stereo Amplifier Kit Cost : Rs.1500 (Includes PCB, Components)
PSU Kit Cost : Rs.1750 (Includes PCB, Components, Capacitors, Rectifier, Thermistors.)
Does not Include : Hardware's i.e Transformer, Heat Sink, Cabinet, Wires
Same with Gold Plated PCB's : Rs.1500 Extra. (Including Amp and PSU)
Packing + Shipping (Courier) Rs.250 (Extra)
Lead time : with in 7 Days from Confirmed Order with Payment.
Note: Kits Available only with in India, No International Shipping.
Part Specs:
FET 2SK170 , 2Sj74 from Toshiba.
ZTX450, ZTX550 from Zetex
Resistors: KOA Speer Electronics, Inc USA-
MIL-R-22684 : 0.5watts 1%, Metal Film Resistors , with (300volts operating voltage.), 3Watts 5% Metal Oxide Resistors.
RN55 of Vishay is same spec as MIL-R-22684
All resistors are of same Spec, from same manufacturer.
Capacitors, 20,000 uf 50V, 105 degree C
Suds
Mail : [email protected]
suds
can you please educate us on the heat sinks and transformers required
exactly what would be needed here
suds
i might have a direct source for heat sinks ( the guys who actaully own the extrusion plant )
i want to see if any of their heat sinks would do
ditto on the transofrmers too
Sure.. I am checking on sources for Heatsink and Transformer, will pot about it soon...
I got few heat Sink dealers, have to check if that have Heat sink specific to First Watt Amplifiers.. will check and post here.
Also.. I will be getting F3 and F1 Parts soon.. already ordered..
I got a dealer who will be sourcing LU1014.
F1 and F3 Kits will be available with Parts and PCB.
suds you misunderstood
i meant please do educate us on exactly what heat sink and transformers we should look for
it so happens i have a heat sink source myself
One owns an AL extrusion firm and one makes heatsinks for various electronic majors
Heat Sink Requirements are there in relevant Service Manuals.
For Pass F5 Amp
Idle heat dissipation would be around 62 watts (At 1.3 amps per channel)
heat sink rated at about .6 deg C./watt for each transistor.
Finned aluminum, with a series of 2 fins attached to an 8 by 6 base, with mounting surface of 1/4inch device need to be firmly attached to the heat sink. The mounting surface use silicone pads / Mica and silicone grease are the best.
Below are link to heat sink images:
Heat Sink Images.
suds,managed to get a few sold/built??like i mentioned initially,what a super amp kit.just wish i had the requisite skills,etc,etc to get one.dying to know ;)...cheers
Sud
What capacitors are you using in your kit? You did not spec the manufacturer below.
