NET RADIO "not connected" on RX-V1067 Yamaha Receiver
clabrut
ISSOIRE
Hello
Does someone already had this problem?
Here are the points that have already been checked:
- Power supply disconnected completely
- Resets network settings (P116 of the manual)
- Test DHCP and manual IP address, the result is always the same.
- Firmware update (by USB key), so it is V3.43
I'm sure of my network setting and the DNS parameters (free (212.27.40.240)) and vtuner work fine on my personal computer with the same parameters.
In attachement, i show the log of my firewal, the rules matches fines !
What is surprising is that the RX-V1067 network interface works perfectly for MP3 playback on the network is functional.
Do you think that using the RS232C interface (via Putty for example) it would be possible to reset the operation of NET-RADIO? (VTuner account for example?).
I also saw a tool "Yamaha Receiver Manager" also helps deepen the settings, is that I could use this to solve my problem? (or could I get this tool?)
Thank you for your help
