Anil. The baffles are looking very neat indeed! Are you going to be doing anything more with the base? The base, in its current shape, does not look to be wide/long enough for it to be stable - esp once you place the drivers on it. It will run the danger of tipping over.
Anilva, Great finish levels, the baffle looks damn neat. Are you gonna mount it emerald physics style where the driver partly sticks out at the top?
Alnico magnets are the ne plus ultra of transducer magnets, even for phono cartridges.
I have a very expensive version of such a design and I think it is truly outstanding.
In my humble opinion, open baffle designs properly implemented create one of the most engaging soundfields possible and, especially if combined with a vertical line source arrangement, the most room friendly design available. Alnico magnets are the ne plus ultra of transducer magnets, even for phono cartridges.
I have a very expensive version of such a design and I think it is truly outstanding. All the best with your project.
Wow those look tasty!
I have a few question.
Are you using any vertical bracing apart from the sides ? as in do you plan to have anything running down the middle of the back? Also are you using any damping behind the baffle ? What is the thickness of the baffle you are using?
Regards.
Hi Anil
Inquiring minds want to know when the speakers( either the OBs or the Horns) will be ready for an audition?
George
