please suggest rear speakers
piyush608
new delhi
i am planning to buy rear surround speaker for my HT room.i have narrowed down to
polk owm3
monitor audio br1(currently my front as well)
or any other in similar price range
please suggest which one to go for .also if there is any other better choice
my current config
avr:1713
front MA br1
center:MA MR center (ordered)
room dim:10*13*10(lXbXh)
also please advise on that at what height the rear speakers must be installed and cables(specs) which gives good performance
length of wires will be 25 and 35 feet respectively
OWM3 are more of all purpose in-wall speakers. I've listened to OWMs and TSi 100s from Polk. The TSis sound much better but the OWMs look much sleeker. In your case since the fronts are on MA the natural choice would be MA
polk owm3
my current config
avr:1713
front MA br1
If you are on a tight budget then you can go for MA BR1. If you can spend few extra money, go for BR2 and use your BR1 for surrounds. I bet you won't regret.
What I've learned about hifi products so far is... for best performance in HT setup all speakers should be from same brand and from same series. This is because guys like me don't have the ears/knowledge to pick up perfect matching speakers from different brands/series.
I have a pair of bipolar surround speakers for sale , if you are interested have a look at for sale forum.
polk owm3
my current config
avr:1713
front MA br1
Pls look for the frequency range from your towers to rears, they need to connect well with each other, IMHO would suggest to go for MA rear's.
