Plz lemme know what can be the solution for my problem!
Yogesh Khadtare
PUNE, MAHARASHTRA
I have Sony HT-M5 explosive 1580w RMS 5.2ch home theater component system and NX AUDIO rx4000 pro amplifier powering my heavy subs. As you can see in video I have serious lights dimming in home. Is this because all the plugs I am using are next to each other? Should I shift my NX AUDIO rx4000 pro amp to another 15A switch of my room which is for air conditioner? Here is the video
https://m.youtube.com/watch?v=krvBp5tXq4Q
Given the details of the setup you have, it does pull a lot of electricity....firstly check if your electric meter can handle all the appliances you have......
Secondly, try operating from a different outlet......hope the outlets have their own dedicated MCBs or are fused....
Take Care
Hi Yogesh,
If you have 3 Phase supply then try to distribute the load across the three phases. If you already have ACs / Heaters running then they will also draw some power so preferably they should be on a different phase from your entertainment system.
Warm Regds
PSRK.
