To me, AC is just a fluctuation of sine wave. A fluctuation of 50 time in a second gives you 50hz. How does the cable improve SQ?
In addition, all the AC will then converted into DC before regenerated back as sine wave to the speaker. How does the cable able to alter anything in the chain?
Not to offend anyone, I was trained to think this way.
Things are a bit more complicated than that. Honestly, I too only started becoming more aware of the complexities of a power supply (especially for AC power supplies) after FM Kanwar patiently tried to explain a bunch of this stuff to us in some of his threads.
To quote from the article:
Real power is the capacity of the circuit for performing work in a particular time. Apparent power is the product of the current and voltage of the circuit. Due to energy stored in the load and returned to the source, or due to a non-linear load that distorts the wave shape of the current drawn from the source, the apparent power will be greater than the real power. A negative power factor occurs when the device (which is normally the load generates power which then) flows back towards the device which is normally considered the generator.
Linear loads with low power factor (such as induction motors) can be corrected with a passive network of capacitors or inductors. Non-linear loads, such as rectifiers, distort the current drawn from the system. In such cases, active or passive power factor correction may be used to counteract the distortion and raise the power factor. The devices for correction of the power factor may be at a central substation, spread out over a distribution system, or built into power-consuming equipment.
Power factor - Wikipedia, the free encyclopedia
I'm not saying that power cables act as power factor correction equipment. But surely you can appreciate the fact that an audio amplifier interacts actively with its power source, not passively (i.e. it is not merely a piece of wire with resistance - like a light bulb). Hence, this is a bit more complex than Ohm's law for DC current and impedance.
Perhaps these are some of the contributing reasons why audio equipment setup is so fragile, and why for high resolution systems (and setups), even innocuous changes like power cable swap can cause audible changes to the musical flavor of sound reproduction.
