Projection on white wall is better than spandex screen?
Wharfedale EVO4.4 Speaker
ranjithkumar10
Hey everyone, I recently purchased XGIMI H1 projector after doing a lot of research. I've been using it for more than a month by projecting on a white wall and it looked awesome! Crisp 1080 projector!
I thought it would look even better on a fixed frame screen! So I hired a carpenter, got a 100-inch diagonal frame done, bought 4-way stretchable white spandex material, stretched and fixed it to the frame. It looked like this!
The frame looked amazing but the projected image on the screen is not as good as the wall. It looked a bit washed out and it is not crisp anymore. It looks like a 720p projector now! It has some kind of dreamy glow effect now. I think the white color light is being spread out on the screen. Colors are not as clear on the wall.
Also, The screen looks a bit transparent and light is being projected onto wall behind the screen a bit.
I'm planning to use a coat of white paint or grey paint on the spandex screen? Will it help me fix it?
Has anyone experienced this issue with white screens? Please help me fix this.
Here's a comparison between wall and screen.
The difference is not clearly visible in the captured photos but there's a clear difference in real.
Few more photos of my screen -
danielnaveen2003
There's your answer, reflected light from behind your screen is messing it up for you. Spandex is needed only for a acoustically transparent screen. You don't seem to have any speakers behind it. So what was the need? If you must use spandex use a (white) blackout cloth immediately behind it, else move the screen a bit forward and paint the rear black. In the second method you will loose some brightness but the screen will still be AT (if that's needed).
ranjithkumar10
Hi Naveen, I did not know any other material for the projector screen. Can you tell me what material is used normally?
Also, Do you think that painting the screen with a coat of white paint would fix it?
ItsMe
Kerala
No, as mentioned earlier, you could use a blackout cloth as a second layer behind your Spandex to enhance the experience. You should be able to procure it from curtain shops
elangoas
Madrasapattinam
Believe you must have stretched the spandex too much.. When i was doing the AT screen for the first time, i used a single layer white spandex and stretch it too much, so there was a light loss seeping thru the screen.. I was suggested by members to use double layer spandex.. (white spandex stretched over black spandex).. When i did it for the second time, i gently stretched the spandex.. Now, i don't have the light seeping thru the screen..
I use the same projector.. Here is a pic of my 100 inch screen..
indy70
Chennai
Did you play with your projector settings ? You can change image brightness contrast and also temperature. Adjust the temperature till whites look whites (no yellow or blue tint, called as white balancing). Wouldn't recommend painting the spandex it may or may not hold and it may become soggy and droopy.
ranjithkumar10
Thanks guys, I'm planning to use a blackout cloth as a second layer behind the current spandex layer or use a different screen instead of spandex. I'll let you know the results.
mukulmehra
Mumbai Meri Jaan
Did you purchase your projector from AliExpress or Amazon India?
manoj.p
US
Blackout cloth is also white in color. The light will still reflect off it, giving you that glow.
Put a non reflective, non transparent Matt black cloth behind the screen. That should get rid of this issues.
Alfahath
Chennai
How much did you spend in total and please guide me to do the same. Which projector you use sir ?
Alfahath
Chennai
Hello sir, I'm planning to get an xigmi H1 after going thru your reviews baised on that product. The only thing is I need to make a 100 inch 16:9 ratio screen.like yours kindly help and guide me where to buy the materials from . My contact no 9840060332. And I'm a business development manager at a hifi audio company. In Chennai. Thanks in advance.
vij
hyderabad
Pretty good @elangoas . Where did you buy the spandex fabric from? Looking to replace my laminate screen. Please help!
elangoas
Madrasapattinam
Thanks @vij . I sourced the spandex from textile town - Tiruppur, Tamilnadu, thru a friend as well as a FM.. It is locally referred as Lycra, spandex material..
Check around town with these names, if you aren't able to locate them, let me know.. I will check with my friend if he would offer help..
vij
hyderabad
@elangoas Do you have a flat surface behind the screen material or is it hollow?
I was able to find a shop that has Lycra - but it's cotton based and no spandex. So confused. Easiest way(for me) seems to be to ask your source to ship it to me. I am from Hyderabad. But how feasible is this? Seems like a lot of trouble for the person:oops:
elangoas
Madrasapattinam
This is the screen material that i used - https://www.hifivision.com/threads/diy-acoustic-transparent-screen.67092/page-2#post-743619
Does you material look alike ? If not, then it may not be right material..
No worries.. I will check with the member if he can offer help and PM you..
  • Like
Reactions: vij
r_s_dhar
Mangalore
Please could you tell me more about this double layer spandex material and where I could buy it in India? Many thanks in advance
