Right, so the new Macbook Pro's are out with the i5 and i7 processors. I'm looking at the 15" Macbook Pro i5 with 4GB RAM and 500GB hard drive. Basically, I will only be using it to edit standard definition video from a camcorder. Do u think its possible to just edit these SD videos on my PC (AMD 7750, 4GB RAM, ATI Radeon 4850) instead of blowing the bank balance on the Macbook Pro?
Basically, is it worth it or should i just use a regular pc?
