Removing ball-pen markings from wall
Shivam
Uttarakhand
My daughter had a chance to practice her drawing skills on my projector screen today morning. The screen is a simple off-white colored matt finished wall. She used a ball-pen for drawing.
Any suggestions to remove these without painting the wall again ?
May sound funny, but give a try with a white eraser. If the paint is washable, try it too.
For Pencil, that is very effective and I tried it. My attempt for ball pen marks did not succeed. YMMV.
weird trick that works for me..
scrotch brite and same soap that you use to wash utensils..
rub with very light hand and it should be wet.just a drop of soap and some water. wipe it off with a sponge dipped and squeezed in clean water.
if light pen marks. try to use eraser (apsara ones)
either of these should do the trick..
Rub with Cif Cream(surface cleaner) Branded item of Hindustan Lever Limited. Rs.29/ for 120 ml. Instruction on the pack.
Cheers.
sunder.
