Replacement bulb for Sharp xr-11-xc
iaudio
Kuwait/Kochi
Projector gurus, Need some help.
A friend of mine needs to replace the bulb on his Sharp xr 11 xc projector. Other than purchasing from Amazon( where it seems to be available for 100-120$), is there anywhere that he can purchase locally? If so, any ballpark price?
TIA
iaudio
The Amazon and related routes are likely to be the best.
Buying locally the imported bulb will cost much more money and it may invite a lot of delay in getting it. While if one goes for the replacement type of bulb then the quality may not be in order and it's life also may fall early.
V.
Anm,
Ashish will be the right person to advice. I think you need only the bare lamp.
V
