Though I don't know much about the Roon and RPi combo, reading through the installation suggests that you arm the RPi with Roon, much like Moode. Just burn it on an SD card. Then I guess the Roon app on your mobile may catch it.
No there is no package or image to burn to, like moode, according to (
Roon Knowledge Base - LinuxInstall) we have a script that either we download and run or directly run the commands (I posted earlier) to download and run the script, that should convert Rpi to roon bridge. I will try and report.
As far as I know and have read, NUC, with i3 processor is essential to run the core. But if you are running the core on Synology, I don't think you need a NUC. The roon remote on your phone or laptop will display and allow you to send songs to the end point. Since I run Roon on a Synology, the only suggestion I can give you is get an external SSD (128gb or 250gb), plug it into the NAS and install the core on that. There is a simple process to do that. If you want I could take you through it. Roon advises against keeping the core on spinning disks; apparently, it reduces the performance. You can keep your music files on the NAS.
Frankly I dont know what I have on Synology, but it says Roon Server. Not sure if it has the core. So assist me to knw how to get core installed on synology. I only saw one spk package for Synology and installing that installed the server I believe, not sure if it included the core (how do we check, I could not find any ip/url to access)
I would not like to bring another extra device NUC in the entire plethora of already existing devices I have ..
.. Hence need to keep it simple. Synology for Core and Server and Rpi as Bridge (or end point or output or whatever you may call). Point me to the direction where I can get Core on Synology (if at all it is possible)
The Roon Bridge you will need if you don't have Roon ready endpoint. If that is the case, and if you manage to figure how to install the bridge on RPi, that should do. NUC would be more useful if you need to install the core itself.
Edit: Just found this link
https://blog.dsnyder.ws-e.com/index.php/2017/03/19/raspberry-pi-3-for-roon-bridge/ Towards the end it kind of explains how to load Roon Bridge on Pi through this software
DietPi - Lightweight justice for your SBC
Yes I have used ditepi albeit for other apps that I wanted to have on pi like RetroPi, so will give it a shot again to use it to install bridge .....
Another update I wanted to give was, while I was reading more on Roon, I came to know it also supports slimdevices (LMS end points) and I am a fan of Picore player, so I gave shot for that, and installed Picore player on pi, configured it for roon and vola, it did start to show up in Roon Zones. This was on another pi with a piHAT DAC (
https://www.fasttech.com/products/1/10023729/5136900-pifi-hifi-dac-digital-audio-card-pinboard-for). I could not hear any surprising change in audio quality, (can blame my audio setup, which is AudioEngines A5+), or maybe I just played one, two tracks as it was late. But I will do a side by side comparision with Moode on Rpi + FiiO DAC to AE A5+ and Picoreplayer as Roon Bridge on Rpi + PiFi DAC+ V2.0 (which is basically hifi berry, same wolfson chip) to AE A5+ and see if I can spot the difference.
But none the less I would like to try Roon's Own bridge as it as RAAT, that is said to have better performance .... so will try all this and report ...
