Samsung B750
ZeusThunderbolt
New Delhi
I would like to know of your opinion on the Samsung B750 series. Do you guys really think that the extra claims are worth the hype and price?
Owners, if any : Could you just look at the side panel and reveal the Panel Code? It should be either SQ01 or SQ02, according to my knowledge. Also, do the widgets work at all? My friend has the 40 inch version and apparently, whenever he tries to access Internet@TV, it says 'Service Not Supported'. Is there a solution to this problem?
