Simple Symmetrical Amplifier by Andrej Lackner
Hi Kaushik. A simple dual power supply is good enough.
My PS details:
Transformer- 20-0-20/120VA
Bridge- KBPC3510
Filtering- 1 x 15000uF/50V in each rail, two capacitors for + and - rail..
Rectified DC voltage= +-28V
shaan
shaan,
that is great ,for newbies this is the diagram
use the components as saan mentioned
I would suggest increasing the capacitance to 15000uF or more in each rail for good bass response, and a 35A bridge rectifier as the peak charging current through the capacitors will be very high and might cause overload to a lower amp rated bridge.
Higher transformer secondary can be used with the changes noted in the following post:
Changes in SSA for use with Higher Voltage PSU
Hi sbg.
Yes it is indeed easy as cut-paste!
All the best on your first diy and first SSA.
Form the BOM list,
Capacitors:
5pF 100V Silver Mica 4
22pF 100V Silver Mica 2
Transistors: 2SJ162 2
These seems not available in SP Road, gave up after checking 3-4 shops.
including 10uF 50V NonPolar 2.
any ideas where this all or preferably the whole BOM can be sourced from one location.
dont feel like taking 95% of the parts and wait endlessly for few part to begin with.
Form the BOM list,
Capacitors:
Hi sbg. Sorry for the late reply.
The pF value capacitors don't need to be silver mica. You can use normal ceramic caps.
The P-Channel MOSFET 2SJ162 is necessary to use with the 2SK1058, so try and see if you can source them. You can use 2SK1530/2SJ201 pairs if the 2SJ162 is not available at all where you live.
All the best.
