Speaker for Devialet 120
do check out audiogon if you are going the used way....
Another US based speaker manufacturer is 'Ohm' speakers - though I have no idea about their pairing with your amplifier. You can also check out 'odyssey' audio. They have a bookshelf speaker based on scanspeak drivers. One more to check out is 'Fritz' audio. Most of the above brands ship direct to your home and offer generous trial periods - with a return option.
P.S - I have not heard any of the above speakers - suggestions are based on reading reviews.
square_wave you are suggesting monitor or towers?
I started reading about Salk and I can see a lot of good reviews and very good feedback from Salk owners. I mailed Jim Salk and he replied and I am visiting his office this Saturday. Soundscape has Accuton drivers,let me go and decide. One good thing is that there is no dealer and retailer in between so I guess Salk products will be good VFM .
Thanks guys for giving idea about Salk.
From salk, the soundscape and veracity range speakers are quite nice. They get rave reviews. Not heard any myself. But people who has visited shows have come away smiling ear to ear after listening to them.
Soundscape are serious high end. The song series are great value. Veracity rides in between.
Thanks apk, will look in to Ohms and Fritz.
I am looking in to audiogon, missed one Salk tower speaker option.
Problem is most of the sellers are far from my place.
Size of the room decides the speaker size. I think you should take your amp when you for the listen. Salks love power. Best of luck
Renjith what is the music that you listen to most of the time?
Since you are moving away from compact 7, is dynamics the only thing that you want more as a virtue of sound upgrade?
Sent from my ONE E1003 using Tapatalk
Neo ,
I am looking for a better speaker in terms of more clarity, dynamics, separation and bass. I like good clarity and effects at low volume.
I dont know how to define it :mad:.
Hi Guru,
Dynaudio I was bit worried about power requirement. I know that it loves power. There is a Tannoy Turnberry in audiogon for a good price but the seller is far from my place.:mad:
At present I am thinking of Salk speakers and I am trying the silk monitor.
I dont want to buy speaker without listening. Salk is near to my place and only problem is all speakers are made to order and need to wait to get it.
dynaudio confidence c1
they are my dream speakers for D120, which speakers are better is subjective, I have heard them and dynamics are better then Compact 7es3. C1 is more 3D compared to compact for sure.
Lots of used once in US
https://www.hifishark.com/model/dynaudio-confidence-c-1
Neo ,
Ok . What is the music you listen to mostly?
I will mostly go with Salk speakers as of now.
Confused between Song 3A, Song Encore and Soundscape 8. Soundscape 8 is expensive so I may settle with Song3A or Encore due to budget.
Guys,
I decided to go with Song-3A (with accutone mid range drivers) speaker and ordered a pair.
Thanks for all suggestions.
Guys,
Congrats.
Can't see a 3A on the site. But must be an active version. But why the ceramic mid range? Not sure if a devialet will match well with a ceramic.
Of course never heard a salk nor a devialet ceramic pairing. So just assumtions.
Hoping you have thought it out well.
All the best
Sent from my PH-1 using Tapatalk
Congrats.
All the best
It is there in website, Song3-A is not active version. It uses a Raal ribbon tweeter, accuton mid range and Satori 7.5 inch woofer.
What is the issue with ceramic?
No issues with ceramic driver.
Imho a ceramic driver might not match well with your amp. Of course im just speculating.
Incase you have heard it with your amp & loved it, There's no point discussing it.
Maybe some others might have heard a ceramic speaker with devialet , might be able to give a better prespective.
