speakers with denon 1713
harman_bajaj
ludhiana
HI GUYS I AM FROM INDIA (Ludhiana) I HAVE DENON 1713 . & SONY ACTIVE SUBWOOFER 160 W
I AM LOOKING FOR BUDGET SPEAKERS SET (ONLY 5 SPEAKERS) - MY PREFERENCE 60% MOVIES / 40 % MUSIC
BUDGET FOR SPEAKERS BELOW 40K INR
OPTION 1 - JAMO 426 HC3 (5 SPEAKERS) -Available for 21.8k at REL. Digital chandigarh (not available in my city, so difficult to carry from there)
OPTION 2 - MAGNAT SUPREME 800 (tower) +Magnat Monitor Supreme 100(surround) + Magnat - Supreme Center 250(total costing me 32k)
OPTION 3 Jamo 416 (available Iin my city at 30k)
Q1.Have any one auditioned any of these sets .
Q2 Do you recommend any other option
Q3 Will my sony Sub can perform good with these or should i buy new sub-woofer (not enough budget)
Q4 what about service/ Warranty as i am in ludhiana ; all are having service center in delhi only i think .
PLEASE REPLY ASAP
Hi.. Polk audio speakers will match with your receiver. Since your prime requirement is movie, it will give warm punchy sound. You may try Tone TL1600
5.1 model or TSI series. It will fit in you budget. There is one dealer also in Ludhiana.
When you have budget/entry level receiver, match them with speakers of highest sensitivity/efficiency...
Take a look @ Sonodyne Genie 2 series... They are rated @ 89db....Should be very efficient with your receiver....
Also try the PSB alpha range speakers... Not sure how much they cost... They are also highly efficient...
