Stuffing in Speaker - Need guidance
I chose two easy way, TL and OB speakers.
I would take the "ghetto" approach because I'm like that!
I would look for material that will take up minimal volume. I would glue up a stack of corrugated sheets at least an inch thick. Then with a knife I would carve out the wedges at least 4 inches long. No calculations used here - just eyeballing the B&W DM302 wedges :)
I would then stick those to any one inner wall.
But one can go crazy with stuff like this - knock yourself out! :p
Hi Sudheer, fir your starting question on how much to stuff, the first 10 replies in this thread gave the minimum information needed i guess.
Basically adding stuff and measuring impedance curve is one way, and the second is by listening.
Do you think your query is answered yet ??
Even easier are speakers over/in the ear. Also called headphones/earphones/IEM's! :p
:D:D this will end all headaches with so many questions.
But somehow i prefer basic bookshelfs over even highend headphones :p:p or...put it this way....even if I use highend headphones, still i can't live without basic bookshelfs atleast....;)
I need music to be spatial, headphones are only for private listening, for me.
And I can't make headphones.
Edit - added 2nd line.
