sonicbliss
Introduction
This is a discussion of Earl Geddes sub setup method which deals with minimizing the ill effects of the room modes that are experienced in a typcial room.
Problem
The bass (50hz-150 hz modal region) in typical rooms is dominated by the room which really swamps it resulting in peaks and nulls all around the room. While it may seem intuitive to flatten the response by EQ, the nature of the problem does not lend itself to simple EQ. After all, the room modes are position dependent. EQ may flatten the response in one position but creates more problems in other positions. The moment the listener moves by a few inches the simple EQ is a disaster.
Whats is Earl Geddes method
Dr Earl Geddes' method solves the problem in a unique way. He recommends multiple subs randomly placed in a room with overlapping mains. By having overlapping mains the mains too contribute bass. Therefore there are many bass sources and each has a different position. While he recommends multiple subs (3 subs) folks have tried with less number of subs and achieved very good results both in measurement and listening tests.
Examples, measurements and reviews
A better description of the problem and the solution in general is found here.
mehlau.net > audio > multisub
Here is a review of system that uses 3 of Earl's subs
http://www.avsforum.com/avs-vb/showthread.php?t=1340062
Here is a nice review (including Geddes mains: Nathan) Earl Geddes Nathan system
Here is a two sub system with measurements
Bandpass sonotube subs - Home Theater Forum and Systems - HomeTheaterShack.com
And finally here is something that would interest the most of single sub owners Bass Integration Guide Part 1 | Hifi Zine
Though the article does talk about measurements being available in part 3, yet part 3 is, unfortunately, not avialble at the time of this post.
Finally here is an experienced member talking about the fact that the actual type of sub (sealed, ported or bandpass) does not really matter. http://www.avsforum.com/avs-vb/showthread.php?p=15793728#post15793728
If anyone does try the setup, do provide your feedback here.
While I have not tried the setup, at the moment I am working on bandpass subs based on this philosophy of 'multiple sub with overlapping mains' as per Dr Earl Geddes.
Sonicbliss
Problem
Sonicbliss
