Subwoofers, center, floor standing
asoft_amit
Belgaum
Hello friends. Please guide me to select Subwoofers, center, floor standing.
I have gone through some list.
Subwoofer- 12" Klipsch, polk, definitive, jbl, SVS and b&w are good but costly.
Center- Klipsch, Elac, jbl Again tannoy, b&w are costly.
Floor stand- b&w, definative tec, polk, Klipsch
Please give me cost effective speakers. I am going for 7.2.2 or 9.2.2 . Budget 2.5 to 3L
Go with 7.2.1 to start with. Later you can add one more sub woofer if needed. If your room size is more than 20x20 then one 15" sub is recommended. Anything below this size one 12" sub will do good job, but u need to choose good powered subs as listed below.
Go with same brand speakers for all left/right/center channel .Also choose the speakers in same power configuration (in RMS watts). By this way there will not be any misalignment issues and sound stage will be good.
Better you do audition of Klipsch, polk, definitive speakers and choose the best one which sounds good to your taste. My preference would be 1.definitive 2.polk ,3.kilpsch.
For Subwoofers check - XTZ ,Rythemic , SVS , REL subs . Go with these high powered sub woofers so you will enjoy movie watching. These Subs are > 90k ,or 1.2 lakhs but they are worthy.
If you have budget constraint go with Polk HTS 12" subwoofer .. but it will not sound as good as above subs, but its better option within budget.
Surround speakers does not matter , u can go with any brand , but choose with same power wattage speakers as fronts or atleast 100 watts rms speakers.
You are not going to find anything high end from most of those brands within that price range. You'll have to drop to the ranks of Base to Medium and even then, you'll be lucky to go beyond 5.1. I'd start start with the basic HT setup and expand as you go and funds permit. Cause at the budget you have, you'll need to set aside a similar amount to power all these speakers. So you're staring at 5l. Minimum.
Polk Audio ES60+ES30+T15+HTS12 = ~2.5l mrp. Now add 2lac on top for the amplifier
